Date/Time: Fri, 13 Nov 2026 10:00:02 +0000
Adjust the tick size of the moving average to match the 6E and LE
View Count: 1336
| [2017-05-21 23:33:28] |
| User375110 - Posts: 28 |
SC: How do I set the tick size on a 20 moving average to match the tick size of the underlying contract for the 6E and the LE? I did the following: chart > chart setting > advanced setting and then I checked adjust tool values to tick size and nothing happened? I want the 20 EMA, for example, to match the underlying price increment. ie if the 6E is trading 1.2185, I want the 20 EMA to also be in increments of .0005, just like the underlying. The same for the LE. If the underlying is trading at 120.375, I want the 20 EMA study to be in increments of .005 . That way when I set an alert to go off when the price equals the 20 EMA, it will work correctly. |
| [2017-05-22 16:40:40] |
This can be accomplished, by using this study: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=247#Round_Study_Subgraph_To_Tick_Size Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
