Date/Time: Mon, 05 Oct 2026 01:29:42 +0000
Clipboard location
View Count: 1100
| [2017-05-15 21:24:08] |
| User182649 - Posts: 31 |
Can you explain how/where I can access clipboard information? thanks |
| [2017-05-15 22:09:47] |
It would help if we have more information about specifically what you want to do. What did you want to copy and paste? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-05-16 14:14:11] |
If i download chart data to a .txt file- I am directed to a notepad with all the text data listed. If I save this info and I want to go back a review it, how do I access the notepad later on. I apologize if I mistakenly called it a clip board. Thanks |
| [2017-05-16 14:38:39] |
You just open the exported text file through the operating system file manager. Make a note of where the data was exported to originally. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
