Date/Time: Fri, 13 Nov 2026 10:04:10 +0000
Cumulative Delta Bar Type
View Count: 1287
[2017-05-15 16:34:38]
User576477 - Posts: 3
Can you change the Cumulative Delta Bar type to Candlestick bars?
Thank you.
[2017-05-15 21:28:32]
Yes you can. This is done through the menu Chart >> Graph Draw Types.
[2017-05-15 23:58:48]
Okay, I see that now. My next question is that I am shading the background for the cumulative delta based on the slope of a moving average...however, it does not fill it in completely only a single line for each candle. For the main graph the background is shaded throughout. I thought it was because it was not a candlestick bar for cumulative delta. How do I fill in the background for cumulative delta background shading?
Thank you.
[2017-05-16 05:12:14]
From our perspective we are not understanding this. It is not clear how specifically you are accomplishing this and what studies you are using.
How are you doing this shading? What particular studies are being used.
Provide an image of the chart or Trade DOM, by following these instructions:
Date Time Of Last Edit: 2017-05-16 05:12:43
[2017-05-16 13:13:46]
I figured it out...Thank you.
