Date/Time: Fri, 13 Nov 2026 10:04:11 +0000
Exclude Evening Session Profiles Except For Last Day
View Count: 1652
| [2017-05-12 16:43:27] |
| User796776 - Posts: 95 |
With this feature set to Yes I am finding that the evening data is being clipped at the 12am time period vs using the evening session start time defined in the chart. In my case, I have the Evening Start at 18:00:00 and Evening End at 09:29:59. Is the intent to show the full overnight session defined by the user or just the current calendar day overnight? Date Time Of Last Edit: 2017-05-12 18:02:28
| [2017-05-12 19:36:56] |
We see a problem related to this which we have now corrected that should resolve the issue you are having.
| [2017-05-16 12:04:55] |
Ok, thats good, but there are no clear actions or expectations of what I need to do to get it working correctly. Do I need to do something or wait for an updated release? |
| [2017-05-16 14:52:06] |
You need to update now to the latest prerelease. Follow these instructions here: Software Download: Fast Update At the time we answered the question previously, the update was not available. This is why we did not say anything further at the time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
