Date/Time: Fri, 13 Nov 2026 10:12:02 +0000
Multiple Instances of Tick
View Count: 992
[2017-05-10 12:36:08]
RonW - Posts: 105
A. If I want to display NYSE tick on the bottom of a chart of emini S&P futures, I need to set up a chart of Tick, and then do a Study/Price Overlay on my ES chart, correct?
B. If I want to put Tick on the bottom of a 5 minute S&P chart and a 1 minute S&P chart, then I need to have 2 separate "source" charts of Tick, correct? Or is there a way to have "Study/Price Overlay" draw proper 5 minute tick bars on a 5 minute S&P futures chart, based on a 1-minute Tick chart?
Thanks,
RLW
[2017-05-10 22:24:43]
We are going to update the documentation about this.
The particular overlay study you need to use is the Overlay (Bar) study.
If you want to overlay the market statistics symbol on two different charts with different time frames per bar, then for each overlay, you need to have a separate market statistics chart open to use as the source chart.
