Date/Time: Fri, 13 Nov 2026 10:12:03 +0000
Transparent Fill to Zero...
View Count: 1069
| [2017-05-09 21:12:07] |
| 33818 - Posts: 30 |
settings aren't working following installation of current version 1554.
| [2017-05-09 23:26:51] |
| Neo - Posts: 198 |
I'm having the same issue.
| [2017-05-10 17:25:44] |
We have fixed this. Update Sierra Chart to the current version with Help >> Download Current Version.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-10 17:26:18
