Date/Time: Fri, 13 Nov 2026 10:08:06 +0000
Relative Strength...
View Count: 1518
| [2017-05-08 15:36:48] |
| User629089 - Posts: 93 |
Hi Support, Is there a Relative Strength type indicator/study in SC? I may be missing it but I'm not seeing anything. This would show what the current volume for whatever timeframe (1 minute, 5 minute, etc.) you want is in comparison to the average for that bar at that specific time of day for the past say 20/30 days or whatever timeframe you set it up for. This is often seen as a histogram and if for example the volume today is light, the histogram would be declining in value and vice versa... Thanks... |
| [2017-05-08 18:25:19] |
Refer to: http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=356#Relative_Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
