Date/Time: Fri, 13 Nov 2026 10:08:07 +0000
How to modify chart trade quantity
View Count: 945
| [2017-05-08 15:10:36] |
| Fabio - Posts: 154 |
Good morning, I need to modify the display default quantity showing on the chart trade window; I need to modify those numbers from 1 - 2 - 3 etc to 10K - 20K 30K etc... Where I can find this option? Thanks and kind regards. Fabio. |
| [2017-05-08 18:26:41] |
This is explained in this section here: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#OrderQuantityButtons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
