Date/Time: Fri, 13 Nov 2026 10:08:04 +0000
[User Discussion] - Pointer Color
View Count: 961
| [2017-05-08 13:50:22] |
| markuz - Posts: 90 |
Is there a way to change the pointer color so when it's over the charts it is a different color?
| [2017-05-08 18:13:50] |
There is no way to do this from within Sierra Chart but you can see if you can do this through the operating system.
