Date/Time: Fri, 13 Nov 2026 10:08:05 +0000
Pending parent order Execution between Curtain Times
View Count: 843
| [2017-05-07 21:02:08] |
| User493032 - Posts: 2 |
1. Is there a a way to only allow the execution of pending parent orders between curtain times for example between 5:10:00 PM CT and 11:50 pm CT. If the conditions stipulated for the pending order are satisfied but not within the stipulated time frame the order will remain dormant. 2. Is there to a way to automatically flatten all open orders (Parent an child) at a specified time for example close all open orders at 3:00:00 PM CT |
| [2017-05-08 18:20:11] |
1. No, this is not supported. 2. You can use the Global Profit/Loss Management feature for this. Refer to: http://www.sierrachart.com/index.php?page=doc/GlobalProfitLossManagement.php This is the specific setting: http://www.sierrachart.com/index.php?page=doc/GlobalProfitLossManagement.php#FlattenPositionsAtSetTime Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
