Date/Time: Fri, 13 Nov 2026 10:16:12 +0000
[User Discussion] - Risk level for stop-limit entry
View Count: 970
| [2017-05-03 00:22:17] |
| User94740 - Posts: 333 |
I am looking for a way to enter a fast market based upon a known level of risk and with a predetermined amount of ticks to the level of entry. Eg. risk(stop) = 5640 I click at this level and then the tool should calculate and place the entry 10 ticks from the risk level to show eg 5630 or 5650 as my entry level. Target is also important and predetermined. I have taken a look at the reward/risk tool and glanced over the studies, but nothing suitable. Is there anything else SC has to offer or maybe I overlooked something? thx!
Date Time Of Last Edit: 2017-05-03 00:22:56
| [2017-05-03 04:23:22] |
This thread is marked as a User Discussion but have a look at this study because it might be helpful: Order Types: Triggered Limit Order Entry Study You can also modify it to meet your requirements. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-03 04:23:43
