Date/Time: Fri, 13 Nov 2026 10:16:10 +0000
missing quotes on spreadsheet
View Count: 887
| [2017-05-02 15:24:27] |
| taipeicity - Posts: 52 |
hi, on my spreadsheet, the following symbols missing quotes always, INTC, MSFT, AMCC, CSCO what is the problem? |
| [2017-05-02 16:33:31] |
You need to use the stock symbol format which includes the exchange and primary exchange. Refer to: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Stock Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
