Date/Time: Sat, 27 Apr 2024 04:56:19 +0000
SC and AT
View Count: 1753
[2013-04-03 07:54:36] |
Just install as many copies of Sierra Chart as you need and login to them with your Sierra Chart Account information. Configure them to connect to whatever service that you need. Additional information can be found here: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
