Date/Time: Fri, 13 Nov 2026 10:16:18 +0000
Replay
View Count: 965
| [2017-05-02 06:49:30] |
| User291323 - Posts: 8 |
Good morning, I have the following problem: If I want to use Replay function, I click on replay and a panel appears. Only Play is active. If I click on Play, it appear new panel Clear Replay/Backtest ....Either I click on yes or not, the only Play is active only and I can't start to replay charts. Pls see attached photo. Thank you for an answer. Rgds Ivan
| [2017-05-02 16:47:41] |
You need to scroll the chart back. Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/ReplayChart.html#BasicInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
