Date/Time: Sat, 15 Aug 2026 09:21:18 +0000
Market Depth Historical Graph
View Count: 1004
[2017-05-01 04:41:07]
User99934 - Posts: 227
When using the market depth historical graph on one trade chart, it worked fine for a while but now window is black.
[2017-05-01 12:08:32]
When put on constant range scaling, problem is OK.
[2017-05-01 12:48:29]
In order to stop screen flicker when new trade comes in, I use display market depth last quantities after last bar. However, the first digit in the market depth is truncated.
[2017-05-01 16:51:32]
We do not see why the scale would make any difference if you are changing the scale for the main price graph.
Also, you should not see any screen flicker. An issue like that is unheard of unless you have a system issue.
Increase the bar spacing:
http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#ChangingBarSpacing
