Date/Time: Fri, 13 Nov 2026 10:24:20 +0000
[User Discussion] - Tittle Bar - issues in Windows 8.1
View Count: 1365
[2017-04-25 23:28:12]
Marek F - Posts: 254
I had a Windows 7 on my old computer, and the Title Bar and Minimize, Maximize, Remove Buttons are the same type in the Main Window and Chart Windows (it's okey). See pic SC-W7.
I purchused a new computer with Windows 8.1, and the Title Bar and Minimize, Maximize, Remove Buttons are not the same type in the Main Window and Chart Windows. See pic SC-W8.1.
Also cann't be customized the Title Bar of the Chart Windows from a level of operating system.
Detached charts have the same type of Title Bar and Minimize, Maximize, Remove Buttons like Main Window (it's okey). See SC-W8.1 detached.
Is possible to fix this issues?
Date Time Of Last Edit: 2017-04-25 23:33:28
imageSC-W7.png / V - Attached On 2017-04-25 23:24:57 UTC - Size: 183.6 KB - 514 views
imageSC-W8.1.png / V - Attached On 2017-04-25 23:25:05 UTC - Size: 194.99 KB - 543 views
imageSC-W8.1 detached.png / V - Attached On 2017-04-25 23:25:11 UTC - Size: 84.31 KB - 502 views
