Date/Time: Sun, 25 Oct 2026 01:31:44 +0000
SUB Instance Sync with Main Instance
View Count: 1804
| [2017-03-21 04:11:02] |
| Robert D - Posts: 24 |
Sirs, I did many modifications to my main instance and I would like to sync these modifications to my two sub instances if possible. If not, is it possible to delete the two sub instances and create new ones that match the modified main instance. Thank you, Bob |
| [2017-03-21 04:47:53] |
Exit from the sub instances. And then copy the Sierra3.cfg file from the main instance folder to the sub instance folders. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-03-21 04:53:01] |
If the changes were to Chartbooks, you need to copy the Chartbook files over from the main instance to the sub instances. Refer to: https://www.sierrachart.com/index.php?page=doc/Chartbooks.html#CopyChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
