Date/Time: Mon, 02 Nov 2026 01:59:48 +0000
User Question
View Count: 876
[2017-02-22 18:39:40]
I have one technical question about range bars.
I want 5 ticks for every bar, but it works only if I set up 4, and sometimes there are 6 or 7 ticks per bar.
In attach an example.
What should I do?
This situation happens for Interactive Brokers and Barchart datafeed, it’s not a data issue.
Sierra Chart Support
imageIssue footprint.png / V - Attached On 2017-02-22 18:38:36 UTC - Size: 82.85 KB - 362 views
[2017-02-22 18:51:24]
For questions like this use the Support Board because it makes managing support easier for us. Otherwise, support gets completely out of control and unmanageable for us and ends up hurting everyone and delays responses. The most qualified response will come only on this Support Board and from no other source.
We have posted it on the Support Board for you.
For this issue, refer to help topic 47:
http://www.sierrachart.com/index.php?page=doc/helpdetails47.html#GeneralInformation
The only explanation is that the Intraday data records for those chart bars are in a larger unit than 1 Tick and Split Data Records is not enabled.
Date Time Of Last Edit: 2017-02-22 18:54:49
