Date/Time: Sun, 22 Nov 2026 05:00:35 +0000
Corn P&L
View Count: 895
| [2017-02-08 09:09:23] |
| User153928 - Posts: 35 |
Hi, on my corn P&L column in the Dom I have those big numbers like -18216.03 and the next is -18228.53 which is 12.50 a tick which is correct I cannot find the setting to change so it shows the correct amount not those big numbers thanks Walter |
| [2017-02-08 10:25:16] |
The first thing to do is to refer to this page here: http://www.sierrachart.com/index.php?page=doc/helpdetails77.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-03-14 18:35:36] |
Thanks but I have it set up to currency etc. OK and it works fine on everything else except corn there is something I'm missing I just cannot find it and my friend Rick Kosolofski has the same problem and he is pretty good with Sierra Charts but he gave up on trading corn since he cannot figure it out too I bet it is something simple, now I'm stuck what to do? Walter |
| [2017-03-14 22:23:26] |
We will have to look into this sometime after the market close using remote assistance to your system. Make sure your current telephone number is set here: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-03-15 03:41:38] |
We determined that the problem is with Interactive Brokers Position Average Price data. It is an issue on their side. Not within Sierra Chart.
