Date/Time: Mon, 02 Nov 2026 00:27:49 +0000
Compare Volume Diagonal level?
View Count: 2226
[2017-02-04 02:45:12]
User701247 - Posts: 117
For comparing Bid Ask volumn, there is a sample as shown below, moreover, I would like to know on what coding look like to compare Volume Diagonal level.
Does anyone have any suggestions?
Thanks in advance for any suggestions
For same Volume level
p_VolumeAtPrice->BidVolume > p_VolumeAtPrice->AskVolume
Date Time Of Last Edit: 2017-02-04 02:46:15
[2017-02-06 18:43:47]
We will work on some documentation for this.
[2017-02-07 05:14:28]
We have updated the documentation here for the member functions you will want to use:
ACSIL Interface Members - Variables and Arrays: sc.VolumeAtPriceForBars Member Function Descriptions
The functions you want to use are:
int sc.VolumeAtPriceForBars->GetSizeAtBarIndex
bool sc.VolumeAtPriceForBars->GetVAPElementAtIndex
Refer to the updated documentation. Be sure to reload that page.
So you will want to get the Volume at price data at a particular price level and the volume at price data at the next higher price level and then do the calculations you need between the bid and ask volumes.
[2017-02-07 05:19:36]
Also if you look at this function scsf_VolumeAtPriceThresholdAlertV2 in /ACS_Source/studies8.cpp in version 1510 of Sierra Chart, you will see diagonal comparisons.
So that is an example as well.
[2017-02-07 05:38:26]
For Volume Diagonal level
Would it be correct statement?
Thank you very much for any suggestions :>
if (p_NextVolumeAtPrice->AskVolume > p_VolumeAtPrice->BidVolume)
[2017-02-07 09:03:32]
We do not provide programming help, and there is nobody who can answer this question for you from that one line of data since no one knows exactly how those pointers have been set.
And also if you are asking this question, it demonstrates that you have insufficient background knowledge to be doing this type of programming to begin with. It is not difficult to learn though.
We recommend that you look at the documentation and also study the code in this function more closely to make sure you thoroughly understand it:
