Date/Time: Sun, 01 Nov 2026 23:30:50 +0000
ExtendedArrayElementsToGraph Function ACSIL
View Count: 1072
| [2017-01-27 15:19:07] |
| User96015 - Posts: 55 |
Dear sir, I built an indicator which uses extra arrays of subgraph for calculation. But I have a problem because when chart updates with a new bar, the values put in extra arrays after current index are overwritten by 0. So I' m not able to do my calulations. Can you solve it? Thx. |
| [2017-01-27 17:56:22] |
This is true. Any data in the arrays after the element for the last chart bar will be reset back to zero as new bars are added to the chart. So you always need to recalculate those or do not rely on them and allocate your own array.
