Date/Time: Sat, 12 Sep 2026 07:51:37 +0000
AMPFUTURES: TT does not support sierra charts???
View Count: 1587
[2017-01-04 00:09:29]
User742717 Mike - Posts: 86
Hi SC
Today, I got error:
TT FIX Data: Received a Logout message. Text = Unable to login to FIX Adapter AMPNON1ORPR: TTUserSetup Error - XXXXXX is not authorized to use FIX Adapter. Please contact your TT User Setup Administrator.
I've had it before, I just contact AMPFUTURES and they fix it on their end.
I just got told this:
AMP | Ignacio
ok TT does not support sierra charts , you would need to move data feed to rithmic or CQG
I was using TT on Monday with no problem, he replied:
AMP | Ignacio
sierra does not support TT no more
Can someone please confirm/deny?
Edit: Version: 1504
Edit: Anyone else needing to change, the form is: https://clients.ampfutures.com/sierra-chart-live-trading-setup-request
Date Time Of Last Edit: 2017-01-04 08:27:18
[2017-01-04 00:19:49]
This is generally correct but more correctly it is that AMP is no longer supporting the TT FIX adapter.
So you do need to use Rithmic or CQG.
