Date/Time: Thu, 17 Sep 2026 11:23:42 +0000
Input symbol from different chart
View Count: 963
| [2017-01-03 23:54:33] |
| Gabriel - Posts: 1 |
Hi SC, let´s say I have opened three charts within one chartbook, C,CL and HO. When I want to change the symbol in any of these charts, I click on the specific chart, press F5 and change the symbol. How can I create a tool window, which would contain three rows data, each for the specific underlying mentioned above where I just change one symbol in the toolbox and the corresponding chart will also change to the new symbol. Thanks. |
| [2017-01-04 00:03:45] |
This can be done with the Associated Watch List: Changing the Symbol of a Chart: Using the Associated Watch List Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
