Date/Time: Thu, 17 Sep 2026 10:22:17 +0000
4K SCREEN SOFT
View Count: 1200
[2016-12-23 13:09:51]
User454054 - Posts: 29
DOES THE SIERRA CHART HAS THE 4K SCREEN SOLUTION FOR BETTER TABLE OR MORE CLEAR ?
[2016-12-23 13:29:38]
michelh - Posts: 162
4k is a function of your video card & monitor - not your software. Yes, I use a 4K monitor and you can see so much more data than with FHD hardware.
[2016-12-23 16:15:24]
It seems that need the software have some support for the 4K function. Because the letter will be scaler and the chart will have some broken as the attached pictures
imageletter.png / V - Attached On 2016-12-23 16:14:50 UTC - Size: 21.73 KB - 477 views
imagecontrast.png / V - Attached On 2016-12-23 16:14:57 UTC - Size: 59.72 KB - 489 views
[2016-12-23 18:45:16]
We do not understand the problem you are having and we do not understand what you are trying to show in the attached images.
