Date/Time: Thu, 17 Sep 2026 10:21:30 +0000
draw/mark multiple bars
View Count: 1245
| [2016-12-22 23:43:47] |
| User970210 - Posts: 102 |
Hi, I would like to draw/put mark eg. a box over multiple bars top/bottom based on conditions I created. Please advice. thanks |
| [2016-12-23 04:16:22] |
This can be done with the Color Bar Based on Alert Condition study. Refer to: https://www.sierrachart.com/index.php?page=doc/ColorBarBasedOnAlertCondition.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-12-23 13:59:49] |
thanks for the reply. but I am trying to find way to color bars say 3 consecutive bars based on a condition. any suggestion? |
| [2016-12-23 18:42:14] |
Yes this is possible. A prior chart bar can be referenced. Refer to: Study/Chart Alerts And Scanning: Referencing Data Other Than on the Last Bar/Column In the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-23 18:42:30
| [2016-12-24 00:06:17] |
thanks. I have no problem to construe a formula for condition, but would like to have draw type eg. dot line over top of last 3 bars.
| [2016-12-24 06:11:31] |
The particular Draw Style selected will only appear on the bars where the condition is true. There is no other possibility unless you use ACSIL. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-24 06:11:44
