Date/Time: Wed, 21 Oct 2026 07:20:22 +0000
Sierra Chart won't start
View Count: 885
[2016-11-14 14:37:21]
User96653 - Posts: 4
This morning when I attempted to start Sierra Chart I got the message:
"The procedure entry point GetLogicalProcessorInformation could not be located in the dynamic link library KERNEL.32.dll".
I updated Sierra Chart to whatever the latest release is (or was) last week, and it ran ok after that. I don't know of any other changes to my system.
Any help would be appreciated
[2016-11-14 14:46:24]
We see you are using Windows XP. This function is only supported on Windows XP with service pack 3.
So make sure service pack 3 is installed. Hopefully you will have no trouble getting that.
However, you should really update to Windows 7 or higher.
