Date/Time: Wed, 21 Oct 2026 09:34:12 +0000
DTS Connections not working after 1473 version install
View Count: 1230
[2016-10-16 21:45:07]
User23815 - Posts: 219
I trade through Gain/Stage5. After the install of version 1473 the saved DTS connection settings I have for my Live and Demo connections at Gain don't work. I get " Invalid saved settings format detected" I get the error message when I try to load the saved settings in the DTS window. I didn't change anything and have had these settings for awhile. Help please. Thanks
[2016-10-17 02:48:42]
We added a note to the version notes for 1473 about this:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1473
You will have to resave the settings.
Date Time Of Last Edit: 2016-10-17 02:49:25
[2016-10-17 20:22:08]
I read the version notes. I then went to DTS and entered settings for first my Demo and then Live accounts. I put in the settings for each, deleted the old name, typed the new name and hit Save. I seem to be able to save one, but not the other. If I save Demo, then the drop down choice for Live doesn't work. If I reenter the live settings and save, then the demo choice becomes inactive. Help please.
[2016-10-17 23:41:59]
You need to save these one at a time. After you save the settings press OK to close the Data/Trade Service Settings window.
[2016-10-17 23:58:12]
I had already tried that. But I tried it again and it still doesn't work. I enter the info, type in the DTS Config and save. Then I say OK and exit DTS. Then I come back to DTS. It is still on the settings that I left but the DTS Config box is empty. I enter the info for the other account. Type in a name. Then I Save. Then OK to exit DTS. Then back to DTS. Currently, when I choose either saved DTS config it goes to my live setting. I am not able to get it to hold and recognize both saved DTS configs.
[2016-10-18 05:41:01]
We need to test this.
[2016-10-18 09:27:30]
We see a problem with this and we will fix it.
[2016-10-19 00:59:39]
User553714 - Posts: 186
I have also tried using this with SC1473 and have the same issues; can you please update this thread when the issue is resolved. Thanks
[2016-10-19 01:05:04]
We are not going to remember to do that. This should be resolved by the end of the week.
