Date/Time: Wed, 21 Oct 2026 11:05:36 +0000
Trade Management by Study
View Count: 1181
[2016-09-30 17:09:39]
User56783 - Posts: 9
Hi. I am using TMS function for stops and can only get the first order to update. For any orders after the first, the stops stay at the original level of the attached order instead of updating. For example, if I want to initiate a 5 lot long position in one lot increments, only the stop for the first lot will update. The other four lots remain at the original stop level. Can you please tell me how to change this so all 5 lots will update? Thank you.
[2016-09-30 17:35:38]
The only solution to this is to have a single stop order.
The study is only going to modify one of the stop orders.
Consider using the Scale In feature to maintain a single stop:
http://www.sierrachart.com/index.php?page=doc/AttachedOrders.html#ScalingIn
[2016-09-30 18:14:09]
Ok. I will try to make Scale In/Out work. Thank you for the quick response.
