Date/Time: Wed, 21 Oct 2026 13:53:40 +0000
Data Service
View Count: 1074
| [2016-08-29 18:26:15] |
| gmorgan111 - Posts: 121 |
I was looking to change data providers and noticed that you do not support Global Futures. On The Global Futures website they list Sierra Charts as a platform they support. Does Sierra Charts support Global Futures for data? Thanks |
| [2016-08-29 21:32:40] |
Global Futures uses Gain Capital and other trading platform services. So they are supported. Refer to: http://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
