Date/Time: Wed, 21 Oct 2026 15:15:09 +0000
Problem with tick data - Replay, symbol NQ
View Count: 1111
| [2016-08-17 17:50:24] |
| User905901 - Posts: 18 |
Hi, I have a problem with tick data in Replay (symbol NQ). Setting is: Global Settings >>Data/Trade Service Settings >>Intraday Data Storage Time Unit:1 Tick and I opened Intraday chart in the past. The same setting was yesterday and everything was OK. The shortest time period (in which price is changed) is 1 minute and it does not matter if the Speed is 10 or 60. How can I solve it? Thanks Regards |
| [2016-08-17 17:55:31] |
Refer to the instructions here: http://www.sierrachart.com/index.php?page=doc/TickbyTickDataConfiguration.php Also refer to: http://www.sierrachart.com/index.php?page=doc/ReplayChart.html#HistoricalIntradayDataRecordTimeframeEffect Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-08-17 18:15:09] |
Thanks. This instruction has helped: "To ensure the Intraday chart data file for a symbol has complete tick by tick data, you will need to fully re-download the data in the Intraday charts by going to an Intraday chart for a symbol and selecting Edit >> Delete All Data And Download." Regards |
