Date/Time: Wed, 21 Oct 2026 14:37:31 +0000
CQG Unable to Connect
View Count: 1111
[2016-08-17 16:10:16]
User56866 - Posts: 28
Is there a problem with CQG today? I have been unable to connect for over an hour.
Attached is the message log
Private File
[2016-08-17 17:13:29]
Yes there have been multiple CQG Web API server problems earlier today. This is not within our control.
Date Time Of Last Edit: 2016-08-17 17:15:45
[2016-08-17 17:14:40]
Thanks.
Do you know who I should contact at CQG regarding these issues?
Ben
[2016-08-17 17:16:07]
Are you still having a problem connecting at this time?
[2016-08-17 17:18:11]
Yes
[2016-08-17 17:20:34]
Provide a copy of the Message Log again following these instructions:
[2016-08-17 17:24:59]
Software version: 1426 | 2016-08-17 12:08:11
Uses New Spreadsheets | 2016-08-17 12:08:11
Enabled for: Advanced Features. | 2016-08-17 12:08:11
Enabled for: Sierra Chart Historical Data Service. | 2016-08-17 12:08:11
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-08-17 12:08:11
Current selected Data/Trading service: CQG FIX Trading | 2016-08-17 12:08:11
Chart Update Interval: 500 | 2016-08-17 12:08:11
Data/Trade Service Settings automatically set. | 2016-08-17 12:08:11
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-08-17 12:08:11
2016-08-17 17:08:10 Local computer time | 2016-08-17 12:08:11
2016-08-17 16:08:10 Local computer time in UTC | 2016-08-17 12:08:11
2016-08-17 12:08:10 Local computer time in SC Time Zone | 2016-08-17 12:08:11
2016-08-17 16:06:16 Server time in UTC | 2016-08-17 12:08:11
Local computer UTC time and Server UTC time difference: 31 seconds. | 2016-08-17 12:08:11
Notice: Your computer's clock is off by 31 seconds. For help with this, press the 'Send for Analysis' button. | 2016-08-17 12:08:11
Program path: C:\SierraChart\ | 2016-08-17 12:08:11
Data Files path: C:\SierraChart\Data\ | 2016-08-17 12:08:11
OS Version Number: 6.2 | 2016-08-17 12:08:11
Locale Setting: C | 2016-08-17 12:08:11
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-08-17 13:24:00
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-08-17 13:24:00
socket (219) | Connected. | 2016-08-17 13:24:00
CQG FIX: Sending the Logon message. | 2016-08-17 13:24:00
CQG FIX Trading | Connected to trading server. | 2016-08-17 13:24:01
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-08-17 13:24:01
CQG WebAPI | Connecting to websocket server. | 2016-08-17 13:24:01
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 216.219.76.101. | 2016-08-17 13:24:01
CQG FIX - FCM name: AMP | 2016-08-17 13:24:01
CQG WebAPI websocket (220) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-08-17 13:24:22
CQG WebAPI websocket (220) | Shutdown and closed. | 2016-08-17 13:24:22
CQG WebAPI | Websocket closed. | 2016-08-17 13:24:22
CQG FIX Trading | Websocket closed. | 2016-08-17 13:24:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-08-17 13:24:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-08-17 13:24:22
CQG FIX: DisconnectFIX called. | 2016-08-17 13:24:22
CQG FIX: Sending a Logout message. | 2016-08-17 13:24:22
CQG FIX Trading | Disconnected. | 2016-08-17 13:24:22
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-08-17 13:24:22
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-08-17 13:24:22
socket (219) | Shutdown and closed. | 2016-08-17 13:24:22
CQG FIX: Disconnected. | 2016-08-17 13:24:22
Date Time Of Last Edit: 2016-08-17 17:44:15
[2016-08-17 17:44:57]
CQG has been contacted about this.
[2016-08-17 18:32:04]
There is a problem with an ISP in London:
Service Affected: Hosting
Service Impact: Partial Service Disruption
Current State: Investigating
Time of Occurrence: 10:57, 08/17/2016
Event Description: Multiple customer lost connections in the London area. (LO1, LO6 and GB3).
Current Summary: We are actively investigating reports of an event affecting several customers in the London Area. Your services may be impacted as a result of this event. Â Resolvers have been engaged.
[2016-08-17 18:34:16]
That explains it. Thank you.
