Date/Time: Wed, 21 Oct 2026 15:14:45 +0000
Understanding NYSE related market stats
View Count: 1641
| [2016-08-17 04:02:58] |
| traderkid - Posts: 3 |
Hi, I have a few question in regards to NISS-NYSE and TICK-NYSE. 1) Does NISS-NYSE and TICK-NYSE stats based on ONLY STOCKS traded on NYSE? Or does it include all ETFs as well? 2) I have noticed that the NISS-NYSE and TICK-NYSE data does not match for the 3-5 minutes with IQFeed/TradeStation/ThinkOrSwim. And after the first 3-5 minutes, they are more or less aligned. If plotting a 1 minute chart for these stats, I could understand if the first minute data is different from these other feeds depending on what is being used to compare the values (i.e. 9:29am or yesterday's close). However, after the first minute, shouldn't the values be more or less aligned? Though from my observation, it takes 3-5 minutes before the values starts to match from Sierra and the other platforms/feeds. |
| [2016-08-17 04:18:24] |
1. It does include ETFs. 2. Refer to: http://www.sierrachart.com/index.php?page=doc/SCMarketStatistics.php#MarketStatCalculationsComparedToOtherDataServices We have nothing further to say about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-08-17 05:00:23] |
Thanks. Is there anything available to see Advance/decline of only the Stocks on NYSE? |
| [2016-08-17 05:12:41] |
This is not supported with the Sierra Chart Market Statistics.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-17 05:12:59
