Date/Time: Wed, 21 Oct 2026 15:15:10 +0000
[User Discussion] - TROUBLE WITH SPREADSHEET TRADING
View Count: 1223
[2016-08-16 15:16:19]
User14682 - Posts: 83
THIS IS A BASIC MOVING AVERAGE CROSS BUT I WOULD ALSO LIKE TO INDICATE THAT 1D5.SGE@3 IS < ID6.SG1@3
THIS WORKS =CROSSFROMABOVE( ID1.SG1@3:ID1.SG1@4, ID3.SG1@3:ID3.SG1@4)
BUT WHEN I ADD ID5.SG1@3<1D6.SG1@3 IS FAILS TO WORK
DOWS ANYONE KNOW HOW TO COMBINE THE TWO?
THANKS
[2016-08-16 15:29:35]
Sawtooth - Posts: 4357
Try this:
=AND(CROSSFROMABOVE(ID1.SG1@3:ID1.SG1@4,ID3.SG1@3:ID3.SG1@4),ID5.SG1@3<ID6.SG1@3)
[2016-08-16 15:34:03]
THE USED TO SAY TRUE AND FALSE. NOW IS IT 0 AND TRUE?
[2016-08-16 15:38:19]
I LOST MY ARROW?
=AND(CROSSFROMABOVE(ID1.SG1@3:ID1.SG1@4,ID3.SG1@3:ID3.SG1@4),ID5.SG1@3<ID6.SG1@3) - I DONT THINK IT WORKED
MY CODES USED TO LOOK LIKE THIS.... i BOUGHT A NEW COMPUTER AND REINSTALLED. EVERYTHING CHANGED..
=OR(AND(AA3>AG3,AA4<AG4,AG3>AC3,AG3>AE3,AG3>AI3),AND(AA3>AE3,AA4<AE4,AE3>AC3,AE3>AG3,AE3>AI3),AND(AA3>AI3,AA4<AI4,AI3>AC3,AI3>AE3,AI3>AG3),AND(AA3>AC3,AA4<AC4,AC3>AE3,AC3>AG3,AC3>AI3))
[2016-08-16 16:11:42]
What SC version were you using on your old computer?
Were you using Old Spreadsheets on your old computer? They have a .scwbf extension. New Spreadsheets have a .scss extension.
Old Spreadsheets are not supported in versions later than 1310.
The auto-conversion from Old to New spreadsheets works in most cases, but not all.
Your original formula should work in the New Spreadsheets, if you didn't change any studies in the Studies to Graph list.
New Spreadsheets output 1/0 instead of TRUE/FALSE
You can use both the ID#.SG#@# format or the original alpha-column format.
There are two advantages to using the ID#.SG#@# format:
1) You can rearrange studies in the Studies to Graph list without messing up your formulas.
2) You can insert/delete columns without messing up your formulas (if you have enough spare Formula Columns before you insert).
Suggestion: Use the ID#.SG#@# format when referencing study outputs, and use the alpha column format when referencing columns A-G and Formula Columns.
