Date/Time: Thu, 05 Nov 2026 23:38:19 +0000
Need help formatting sc.SetAlert() message output
View Count: 1487
[2016-08-16 04:10:32]
User147461 - Posts: 33
Trying to convert an alert message output from TS to SC
EasyLanguage code:
Alert("ABC Sell Signal for " + GetSymbolName + " at " + NumToStr(Close, 2));
TS alert message output example:
ABC Sell Signal for ESU16 at 2190.75
I didn't expect this code to compile but describes the output desired:
sc.SetAlert(sc.SelectedAlertSound, "ABC Sell Signal for ", sc.Symbol.GetChars(), " at ", sc.Close[sc.Index]);
Is this possible to convert to SC?
Thank you!
[2016-08-16 19:09:39]
Yes this is fully possible to do using the standard Format function on the SCString. Refer to:
http://www.sierrachart.com/index.php?page=doc/ACSILProgrammingConcepts.html#FormattedTextString
[2016-08-17 05:57:46]
Thanks for the link! Got it working.
SCString AlertMessageString;
AlertMessageString.Format("%s %s %s %.2f", "ABC Sell Signal for", sc.Symbol.GetChars(), "at", sc.Close[sc.Index]);
sc.SetAlert(sc.SelectedAlertSound, AlertMessageString);
