Date/Time: Wed, 21 Oct 2026 15:15:45 +0000
Problems creating session high/low of MACD
View Count: 1634
| [2016-08-16 01:48:38] |
| User947126 - Posts: 14 |
Hello, I need to capture the day session high/low of MACD (the "SG1" value) to use in an alert I'm creating, and nothing I've tried works. I'm using the "High/Low for Time Period" indicator to get my session high/low. I've tried: 1. Just putting MACD in the "Based On" field of the "High/Low for Time Period" indicator. This almost works, but it calculates the high/low of the ".SG2" subgraph of MACD, which is the MA of MACD, when I want the ".SG1" value, just MACD itself. 2. Setting the .SG2 subgraph of MACD to a value of 1, which makes it the same value as the .SG1 subgraph. I've tried it with both simple and exponential moving averages. When I do this the "High" value shows up correctly but the "Low" value is always zero. 3. Doing my own version of MACD by creating two exponential moving averages and then creating a "Study Subgraphs Difference" indicator on the two moving averages. This looks just like, and has the same values as the .SG1 subgraph of MACD. I then create a "High/Low for Time Period" indicator for this "Study Subgraphs Difference" indicator, but it doesn't work--the high and low values are always zero. So, I'm stuck. Any ideas? |
| [2016-08-16 19:35:13] |
This will be supported in the next release with new Input Data inputs added to the High/Low for Time Period study. Here is an example: http://www.sierrachart.com/image.php?Image=1471376083481.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-08-16 19:44:55] |
| mkata - Posts: 104 |
User947126, You could also use Study Subgraph Daily High Low. http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s371 |
| [2016-08-17 04:48:33] |
Great, thank you.
