Date/Time: Wed, 21 Oct 2026 15:15:45 +0000
Global Settings and Chart Header
View Count: 907
| [2016-08-13 12:33:32] |
| User34124 - Posts: 289 |
http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#RegionDataLine How can I have this as a non global setting? Different for one chart/ set of charts |
| [2016-08-13 14:06:48] |
You cannot. It simply is not supported and there are no plans for this.
