Date/Time: Mon, 14 Sep 2026 18:33:15 +0000
text display study function
View Count: 3702
[2013-03-30 17:07:52]
Yes, the Text Display For Study study only displays numbers. Not text.
[2013-03-30 20:37:12]
You can do something like this by using the Text Draw Style:
http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#DrawStyle
[2013-09-19 15:37:46]
dd78746 - Posts: 22
I also have a need to use the "Text Display For Study" to display Text at the top of the chart. This would be very helpful to see the signals of a chart quickly,at a glance.Please consider this as possible enhancement if it is not too difficult. TIA
[2013-09-19 16:55:47]
You mean text from a spreadsheet?. This is not supported . We do not foresee this. It is not reasonably possible.
[2013-09-19 17:38:13]
dd78746 - Posts: 22
Yes, Text from a spreadsheet. However, it would be just some thing that would be nice to have, I can use a numeric code instead. I just wanted to see if was an easy fix. Since it is difficult, I can live with out it with no problems. TY
