Date/Time: Mon, 16 Nov 2026 23:22:25 +0000
Study Line Color Based On Values
View Count: 2066
[2016-08-10 04:46:35]
User147461 - Posts: 33
I've searched the Support Board for a code example with no luck. Here is what I'm trying to code:
My study produces a signal line that oscillates between a low value of 0 and a high value of 100.
I want to color the signal line green when the value is <= 20, red when >= 80 and gray when > 20 and < 80.
How do I change the signal line color using 3 different colors with ACSIL?
Thank you!
[2016-08-10 06:04:13]
This is controlled through sc.Subgraph[].DataColor:
ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DataColor[]
[2016-08-10 16:54:28]
Thanks for the link! Got it working.
if (SignalLine[sc.Index] > OverBoughtInput.GetFloat() && OverBoughtInput.GetFloat() != 0)
  SignalLine.DataColor[sc.Index] = OverBoughtColor.GetColor();
else if (SignalLine[sc.Index] < OverSoldInput.GetFloat() && OverSoldInput.GetFloat() != 0)
  SignalLine.DataColor[sc.Index] = OverSoldColor.GetColor();
else
  SignalLine.DataColor[sc.Index] = SignalLine.PrimaryColor;
