Date/Time: Mon, 16 Nov 2026 23:22:20 +0000
Please add Coppock Curve study
View Count: 1679
| [2016-08-03 08:32:53] |
| User857142 - Posts: 82 |
Hi Can you add this simple but widely used study- Coppock Curve http://stockcharts.com/school/doku.php?id=chart_school:technical_indicators:coppock_curve Thanks |
| [2016-08-03 21:12:41] |
| jackw - Posts: 57 |
You can add build this yourself using existing studies. I have the formula as: Coppock Curve = 10-period WMA of 14-period RoC + 11-perod RoC 1. Add the Rate of Change study. Set the length to 11. Hide it. 2. Add the Rate of Change study. Set the length to 14. Hide it. 3. Add the Moving Average - Weighted study. Set Based On to the 14-period ROC study you added in step2. Set the length to 10. Hide it. 4. Add the Study Subgraphs Add study. Set Input Study 1 to the study added in step1. Set Input Study 2 to the study added in step3. Your done. I've attached a study collection which will do the above when applied to a chart. |
| [2016-08-03 22:44:11] |
This study is easy for us to add. We will do it in the next couple of days.
| [2016-08-04 03:55:33] |
Thanks to both of you!
