Date/Time: Fri, 03 May 2024 21:10:35 +0000
10 min bracket on Notes TPO chart
View Count: 3340
[2013-07-29 11:42:29] |
trademechanics - Posts: 29 |
Can you confirm on your side with 30 minutes charts using the @ES#C IQFeed symbol? I'm seeing some out of sync days when I overlay the TPO Value Areas from a 30 minutes bar chart into the TPO chart. This should be in sync since we are dealing with 30 min periods. Thanks |
es_outofsync.png / V - Attached On 2013-07-29 11:40:14 UTC - Size: 51.56 KB - 573 views |
[2013-07-29 17:18:20] |
We need to get your chartbook, with this configuration. It should only contain 2 charts. For instructions to attach it, follow these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile We also need to know what your Time Zone setting in Sierra Chart is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-29 21:44:35] |
Still trying to understand what happened here. I created a new chartbook and new charts so I could send to you but when I got all studies set up I noticed that the overlay was now in sync. I went back to my chartbook and I could still see the overlay out of sync. I remembered to reload and recalculate all charts/studies. This ended up fixing the problem, I think, since from that moment all charts became perfectly in sync. Question, when we have charts with one symbol and then change to a symbol which trades on a different exchange, on a different time zone, can this confuse some studies, namely the ones that depend on time to make their calculations? I had all my charts set to ZN and than using the same charts I changed the symbol to ES and it seems that something went off while doing this that apparently was fixed by reload and recalculate the data. Date Time Of Last Edit: 2013-07-29 21:46:23
[2013-07-29 23:08:16] |
No. You should not have to do a manual Recalculate.
