Date/Time: Wed, 21 Oct 2026 15:13:40 +0000
Replay with SC and Jigsaw
View Count: 2064
| [2016-07-28 13:54:18] |
| User23815 - Posts: 219 |
I am using SC, S5Trader from Gain, and Jigsaw. SC and S5Trader both have replay features. Jigsaw will replay on S5. If I am running replay on S5 and connect to SC, will SC use the replay data or will it continue to use live? I am looking for a way to replay Jigsaw with SC. Thanks
| [2016-07-28 17:03:41] |
No, this definitely will not work at all. Live data will always be received from Gain Capital. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-08-17 14:12:23] |
Is there a way to use my SC replay directly to Jigsaw? Jigsaw is an excellent add-on to SC. It would be great if I could use them together in replay. You are Jigsaw compatible, according to them and replay is a valuable tool. Please consider working with them to add this feature. Thanks
