Date/Time: Mon, 16 Nov 2026 23:32:27 +0000
ASCIL Question
View Count: 1153
| [2016-07-25 17:33:55] |
| infpz - Posts: 826 |
I referred someone here for support: http://www.sierrachart.com/index.php?page=doc/AdvancedCustomStudyInterfaceAndLanguage.php#StepByStepInstructions I received a reply: That is exactly what I am(was) using and doing. The template includes a file called "ACSILDepthBars.h" that doesn't exist on either of my computers. Can you assist? Date Time Of Last Edit: 2016-07-25 17:34:07
| [2016-07-25 17:52:28] |
They need to contact us directly on the Support Board. For something advanced like this, you should not beginning in the middle of it. We do not understand what they are saying. What do they mean by "template"? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
