Date/Time: Mon, 16 Nov 2026 23:32:38 +0000
chart settings
View Count: 1042
| [2016-07-23 01:39:59] |
| madra - Posts: 109 |
Hello,date range in file in one of my charts shows 2015-12-07. I have tried to change this for loading 180 days. Even when i manually change the date in the first box or in the box 'use date range' no change is effected. |
| [2016-07-23 01:52:16] |
If you want to load 180 days into the chart, then set the Days to Load setting in Chart >> Chart Settings to 180. For more information, refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
