Date/Time: Mon, 16 Nov 2026 23:32:30 +0000
backup chartbook files, some missing
View Count: 1677
| [2016-07-23 00:20:30] |
| Willson - Posts: 176 |
Had reason to use the chart backup file for this chartbook: 6E Experimental 0708.cht. In SierraData folder I found *.Cbak files for all my chartbooks except This one and several others all with names begining with 6E... I am concerned that they are missing. Any suggestions? Regards |
| [2016-07-23 00:35:50] |
There is a separate folder for Backup files. This is documented in detail here: Chartbooks (Workspaces): Accessing a Backup Chartbook File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
