Date/Time: Mon, 16 Nov 2026 23:44:25 +0000
Crude oil tick charts -- gaps between close of current candle and opening of next candle
View Count: 1591
[2016-07-12 19:33:46]
User282572 - Posts: 6
I see gaps between close of current candle and opening of next candle. Sometimes overlaps of Two or more candles.
I do not see the same problem on other platforms...don't know if I need to change any settings. Sierra chart version:1441
[2016-07-12 20:41:52]
Provide an image of the chart which specifically shows this, by following these instructions:
Date Time Of Last Edit: 2016-07-12 20:42:10
[2016-07-12 23:33:47]
Uploaded the image below:
http://www.sierrachart.com/image.php?Image=1468366316368.png
[2016-07-13 03:54:14]
We see you are using Rithmic. Have your broker change your account to CQG or to service package 5. Either of these are going to be essential have accurate charts based upon variable timeframe bars.
Also follow through the instructions here:
Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent
