Date/Time: Mon, 16 Nov 2026 23:44:38 +0000
Bug? When Chart DOM present 2nds lower region scale & move locked
View Count: 901
| [2016-07-12 12:42:10] |
| User360283 - Posts: 538 |
Not sure if this is a bug. But can;t adjust the second region without first shutting down Chart DOM.
| [2016-07-12 16:52:14] |
So you cannot move Chart Region 2 when the Chart DOM is on? Left click and drag in the column where the numbers are present for the scale for Chart Region 1. So you will still left click in the same vertical position but horizontally further to the right. So this will be further to the right. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-12 16:52:55
