Date/Time: Mon, 16 Nov 2026 23:44:38 +0000
SC historical data for stocks problem
View Count: 842
| [2016-07-12 10:42:06] |
| User025902 - Posts: 8 |
Hello, I have the package 5 (my broker is AMP). Also, I have set the "SC data - All Services package" at the data/trade connections. However when I try to open the historical STOCK chart ( through Find Symbol I put to the selected symbol "AEE" and click on open historical chart), it´s not working. I see only white background without bars. How can I fix the problem, please? Many Thanks |
| [2016-07-12 11:16:36] |
Amp is a Futures broker. You must have a directly paid for account for this. Follow the instructions here: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
