Date/Time: Mon, 16 Nov 2026 23:44:34 +0000
Which version of TT FIX adapter is supported?
View Count: 1287
| [2016-07-11 21:20:35] |
| User572268 - Posts: 2 |
Is version 7.17.60 supported?
| [2016-07-11 22:16:01] |
We are not aware of any issue using the very latest TT FIX adapter version or the older versions. So yes, it is supported. And also multi-broker configurations are supported as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-11 22:16:24
| [2016-07-11 22:22:13] |
Thanks!
