Date/Time: Mon, 16 Nov 2026 23:44:31 +0000
Concerning "Current Announcements"...
View Count: 964
| [2016-07-11 17:26:25] |
| User68474 - Posts: 204 |
...as concerns "existing Symbol Settings will not load". Yesterday, Sunday 7/10/2016,I updated to version 1442. This morning, Monday 7/11/2016, upon logging on, all my charts, alerts appear to be normal, just as saved at last night's exit, and unaffected by this supposed problem. Is/will there be a problem going on somewhere in the background which I will not see ? Do I need to follow the "Update to pre-release 1443" instruction ? Or is that only for those who notice "there is a problem where existing Symbol Settings will not load"?
| [2016-07-11 17:32:37] |
At the end of the day update to 1443. This is very important. Here are instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate You can also install version 1441. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-07-11 18:30:46] |
If I opt to reinstall version 1441, do I need to : " After the new version is installed, make sure the symbol settings are up-to-date by following these instructions here: Global Symbol Settings: Update Global Symbol Settings" |
| [2016-07-11 18:37:27] |
It is a good idea to do this to make sure the symbol settings are up-to-date.
