Date/Time: Mon, 16 Nov 2026 23:44:34 +0000
6C canadian dollar
View Count: 1104
| [2016-07-11 16:31:15] |
| navigator - Posts: 27 |
Effective Sunday, July 10 (Monday, July 11 trade date), Chicago Mercantile Exchange Group Inc. will reduce the price increment of the Canadian Dollar/US Dollar Futures contract (6C) from 1 tick ($10 per contract) to ½ tick ($5 per contract) Platforms should adjust price quotations from .0001 to .00005 but I'm not able to do. How to adjust. Thanks
| [2016-07-11 17:01:03] |
Refer to: Change to Minimum Price Increment for Canadian Dollar/U.S. Dollar (CAD/USD) Futures We see you are using CTS. After following the instructions in that thread, you need to re-download the data in the chart with Edit >> Delete All Data and Download. Although this may not help because there may be a difference with the data prior to today with the price format. After you do this let us know if you still a problem with the chart. And then post an image of the chart following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-11 17:02:20
| [2016-07-11 17:05:58] |
Actually if you still see a problem there is a solution to this if you are using service package 5. You just need to enable Global Settings >> Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds.
| [2016-07-11 17:30:22] |
I set the settings as shown here, also clicking the lower overwrite existing settings from server when automatically updating from server. Price chart looks ok. Will edit>>Delete all data and download after market hours. http://content.screencast.com/users/navigator77/folders/Jing/media/cdce492e-f034-464b-98f0-87e070a8910c/2016-07-11_1024.png
